sjjj
Message 11 of 12
Re: DNS problems
Hi Morris,
I thought it had as it didn't fail for over a day, until I opened IE (I normally use Firefox) and then it died...
After testing again, whenever I open IE it seems to kill it!
Hmm...
CharlieF
Message 12 of 12
Re: DNS problems
Try the command...
ipconfig /flushdns
It might also be worth running a check disk on your C: drive (right click on C:, properties, tools tab, (Error checking) "Check now" button, start, then you will need to reboot your PC)
Charlie
