Message 191 of 207
Re: DNS
This has been an intermittant issue for ages. I get around it by using google dns but as mentioned previously the servers are not as fast as BT!
Today this issue is hitting common web sites for me: BBC, Facebook etc even BT! Anything with https. I had a web chat on mybt with a nice chap called Santosh who was very helpful but had never heard of this issue and seemed to know little about the concept of DNS. He suggested that I call the helpline. I sent him the link to this page.
The last time this happened in our area for any length of time was two weeks ago. Microsoft and others were hit with a huge DDOS attack.
It strikes me either BT are in denial or coping with some issues that they don't want to share with us.
Message 192 of 207
Re: DNS
Problems with exactly the same webpages. Had a similar talk on the live chat as well. Said the problem will be monitored and I can expect a callback on Saturday. Losing a bit of faith, though, as none of the other checks/etc. have made any difference.
Message 193 of 207
Re: DNS
Anyone else still having these issues?
http://imgur.com/j66YQ5R
Message 194 of 207
Re: DNS
Works on my vpn but not my normal connection. ^^
Newbie
Message 195 of 207
Re: DNS
Just started happening for me. Driving me crazy, stopping me from working.
Message 196 of 207
Re: DNS
As a temporary measure, just change your DNS to 8.8.8.8 and 8.8.4.4. You can't change it on a Home HUb if you have one, but you can change it on your PC/device
Newbie
Message 197 of 207
Re: DNS
 thanks liquorice, a pain having to do it on every device as I do indeed have a BT router, but it does solve the problem.
Message 198 of 207
Re: DNS
If you can setup your own DHCP server, instead of using the home hub, you can set the DNS servers for your whole network.
I have the DHCP server on my home hub turned off, and instead use my wireless access point which has its own DHCP server which is configured to use OpenDNS.
That way you do not have to alter any devices, as the DHCP server provides both LAN and wireless requests.
I use a TP-LINK TL-WA701ND access point, but you could probably use an old unused router to do the same thing.
Expert
Message 199 of 207
Re: DNS
This issue is now resolved. http://status.aws.amazon.com/ under Amazon CloudFront gives the details. It was causing problems, apparently, from 1107 until 1741 (UK time). There was a conflict with BT's DNS. Amazon Prime Music stopped working and other sites using Amazon's cloud service where interrupted.
Message 200 of 207
Re: DNS
Not resolved at all. Still issues with it. Can not update Apps or downloaded Apps. Can't get on Tesco's either. I expect there are other sites.
