Hi all Im considering going to BT Infinity and was show this tool to check the Broadband speed available. I know there is an old 7mb connection already (though i did think it was 17mb!!!) anyway checked it out and ive no idea which figure im meant to look at here!!!
Are my Bband speeds the VDSL connection or the ADSL connection???
thanks in advance
hi webby,
thanks for that so the VDSL line because it says available does it mean i CAN get it in my property?? And I thought it was the 78 figure I was meant to look at? I assume i Need to be looking at the download threshold figure and not the rate?
I think what im really stuggling with these figures is how to I find out if the fibre line is all the way to my property
thanks
The fibre only goes as far as the green cabinet, from there Infinity is delivered on the normal copper phone line. You should expect get a download speed of between 78M & 58M for Infinity2. If you decide on Infinity1, your speed will be artificially capped at 55M. Infinity 1 is more than adequate unless you intend streaming multiple UHD channels simultaneously.
