Message 1 of 39
DSL Checker Speed changes
So I'm having an engineer out tomorrow to do a profile reset and hopefully sort out my low speeds, fingers crossed anyway. I was on about 0.8 upload before so I decided to check on The DSL checker website to see what I should be getting and my expected speeds have increased.  Download I was predicted between 32-40 and it's now gone up to 35-46. What would cause them to change and is it likely that once my line is sorted I will achieve these speeds?? Weird seeing a speed increase when I'm not even meeting the minimum speeds on the previous list. Can anyone shed some light on this cheers?
38 REPLIES 38
Recognised Expert
Message 2 of 39
Re: DSL Checker Speed changes
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 3 of 39
What?? I'm not asking for help concerning my low speeds. I'm already getting that sorted and I've already had a thread dedicated to that. I'm asking why my DSLCHECKER expected speeds have gone up. That's all.
Recognised Expert
Message 4 of 39
OK. I was wondering whether you had low connection speeds or just slow speedtests. They can be vastly different for vastly different reasons. I'll now look at your other thread & find out for myself.
Recognised Expert
Message 5 of 39
When you did the BT Broadband Availability Checker what did it say at the foot of the table about Premise environment?
You have quoted its revised Clean range but what is its Impacted range now?
Message 6 of 39
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High Low High Low
VDSL Range A (Clean) 46 35 7.9 5.8 32.4 Available -- -- Yes --
VDSL Range B (Impacted) 35 18 7.5 3.9 13.7 Available -- -- Yes --
ADSL Products
Downstream Range(Mbps)
Availability Date
Left in Jumper
ADSL Max Up to 5 -- 3.5 to 7.5 Available -- -- -- --
Fixed Rate 2 -- -- Available -- -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- -- --
Premise environment
Status
Bridge Tap Y
VRI N
NTEFaceplate N
Last Test Date 17-05-2017
Message 7 of 39
The impacted range has gone up as well. Not by much, but it has increased.
Message 8 of 39
Before on the bridge tap it said U. Now it has a Y, what does this mean??
Expert
Message 9 of 39
Bridge tap u for unknown, bridge tap y for yes, bridge tap n for no.
Message 10 of 39
So I've had the engineer out. Had some resets. Got a home hub 5 and tested again. Download has gone up slightly to about 25, and the upload is between 3-5. Which is an improvement. I'm guessing I've got an impacted line as these speeds fall in that bracket.
