Message 1 of 6
DTLS connections
Hi, I use an SSL VPN for work which attempts to connect as DTLS (UDP:4433).  My BT broadband will never connect using this though and always falls back to TCP:443 (https).  Colleagues can connect fine with their varying providers.  Does BT block this type of traffic?
5 REPLIES 5
Message 2 of 6
Re: DTLS connections
Can anyone advise?? Chat support have just dismissed me.
Message 3 of 6
If you are a businees user then contact BT Businees, this forum is for residential retail customers
Message 4 of 6
i am not, am a residential customer.
Message 5 of 6
OK, it is just that you said you used it for work.
Message 6 of 6
no worries, its my personal connection that i use to connect back to work.
