Dadof4
Message 1 of 16
Dashed line or black “flicker” at top of screen on certain channels
Hi All, I have just upgraded to a new Sony tv/soundbar & uhd YV box and am frustrated with certain channels. Many of the “mainstream channels” – BBC, ITV seem to be OK in both normal and HD variants, as do the BT Sport channels in the main, but others have one of three issues – 1) Flickering at the top line of the screen, 2) White dashed lines permanently at the top of the screen, or 3) A black flashing bar across the top half of the top line of the screen.
The TV Signal & Quality setting on by default is: UHD, 50fps, 8bit. If I change this to 1080p the issue goes away, but it is fiddly (and should be unnecessary to need to do this).
I have just been through all the channels that are affected, but an example is any of the 3 Disney channels, which all suffer from a black/white dashed line at the top of the screen.
Any help would be appreciated as this is quite frustrating! Many thanks 🙂
15 REPLIES 15
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 16
Re: Dashed line or black “flicker” at top of screen on certain channels
Steve_M
BT TV Expert
Message 3 of 16
Hi Dadof4,
Let me raised it internally and see if it's something we can change on our encoders. Won't be quick but I'll get back to you with an update.
Steve
Dadof4
Message 4 of 16
Hi Steve_M. Thanks for that. In case it is useful, I have been sad enough to work through all the channels on YouView and categorised them as follows:
Channels with flickering at the top line of the screen
17 – Really
20 – Drama
21 – 5USA
22 – Ideal World
23 – CreateCraft
39 – The Store (this one has what looks like a barcode across the top left hand line of the screen)
55 – 5+24
68 – TruTV
76 – Jewellery Maker
Channels with white lines/dashes at the top line of the screen (by far the most frustrating issue)
48 – Movies4men
81 – Talking Pictures
84 – Dave ja vu
331 – Sony Channel
412 – Eurosport 1 (435 the HD version seems OK)
480 – Disney Channel (these Disney channels are the ones my children want to watch all the time – typical!)
481 – Disney Junior
482 – Disney XD
Channels with a black flashing bar across the top half of the top line of the screen
317 – National Geographic (373 the HD version seems OK)
318 – NatGeoWild (374 the HD version seems OK)
327 – History
328 – Ci (380 the HD version seems OK)
330 – H2
485 – Nicktoons
As I mentioned in my original post the TV Signal & Quality setting on by default is (UHD, 50fps, 8bit). If I change this to 1080p the issue goes away, but it is fiddly (and should be unnecessary to need to do this). More photo's from different channel below for info.
Steve_M
BT TV Expert
Message 5 of 16
Awesome, thanks!
I've raised it with the team - they are saying it is Wide Screen Signalling – as per ETSI http://www.etsi.org/deliver/etsi_i_ets/300200_300299/300294/01_60/ets_300294e01p.pdf
They're looking into how we can move it out of frame whilst keeping the funtionality.
Steve
Dadof4
Message 6 of 16
Excellent. thank you Steve. That sounds encouraging. Do you know if there is any rough timeline on when a potential fix might be delivered for this?
If you need me to test any updates I'd be more than happy and my children would appreciate their Disney channel being "cleaned up" for sure!
Thanks again for all your help, it is much appreciated.
Sport-Tower
Retired BT Expert
Message 7 of 16
Hi Dadof4, We can confirm the fix has been applied across all affected channels so you should no longer see the data line. Please advise if you experience any further issues and many thanks for highlighting! Kind Regards Russell
Dadof4
Message 8 of 16
Hi Russell,
Thank you for the update, I really appreciate your support. Things have moved slightly, but many channels are still the same. In summary, the 3 Disney channels (480, 481 & 482) now no longer have the white dashed line at the top row of the screen, but there is now a flickering in the first row on these channels. I have been through all the channels again and the results are as follows:
17
Really
Still flickering at top line of screen
20
Drama
21
5USA
39
The Store
“Barcode” still there across the top right hand line of the screen (was previously left) & flickering on top line of screen.
55
5+24
68
TruTV
76
Jewellery Maker
Not being broadcast currently, so couldn’t check J.
30
5 Star
Flickering at top line of screen
310
Gold
324
ID
412
Eurosport 1
Previous white dashes gone, now flickering at top line of screen. 435 the HD version seems OK.
413
Eurosport 2
480
Disney Channel
481
Disney Junior
482
Disney XD
487
Boomerang
488
Cartoonito
The "flickering" is very noticable when changing from a "non-flickering channel" (like BBC One HD or a BT Sport channel for instance).
48
Movies4men
White dashes still there
81
Talking Pictures
84
Dave ja vu
331
Sony Channel
Seems OK 🙂
Channels with a black bar (flickering on some channels) across the top half of the top line of the screen
22
Ideal World
Black bar still across top half of top line of screen.
23
CreateCraft
38
Quest+1
Black bar across top half of top line of screen.
40
Rocks & Co
43
Gems
49
TJC
87
Country
130
BBC News
135
RT
313
Good Food
317
National Geographic
Black bar still across top half of top line of screen. 373 the HD version seems OK
318
NatGeoWild
Black bar still across top half of top line of screen. 374 the HD version seems OK
327
History
328
Ci
Black bar still across top half of top line of screen. 380 the HD version seems OK
330
H2
485
Nicktoons
Being broadcast in widescreen currently, so couldn’t check.
gomezz
Recognised Expert
Message 9 of 16
Did you try the other suggestion of turning overscanning off on your TV set?
Dadof4
Message 10 of 16
Hi gomezz
I just did a simple test on my Sony Bravia TV, which itself has a built-in YV tuner. I tried the first channel that gives me a flickering top line from the BT YV box which is the Really channel (channel 17). When I watch this using the TV's built-in tuner all is fine, howver when I switch inputs to HDMI1 (where by BT YV box connects) I get the probelm. If I then change settings in the BT YV box, so that it only outputs 1080p all is fine, however, given my TV is 4k, I want to keep the TV Signal & Quality setting on UHD, 50fps, 8bit by default. I looked all through the various Picture options on the TV itself and can't see anything that would let me control overscanning :(.
