Message 1 of 3
Data Only SIM for a mini hub
I was given a BT mini hub when I had an issue with my broadband. It is now deactivated but I was wanting to buy a data only SIM card and use the mini hub at my work where reception is terrible. I already have 5 SIMs on a family plan. Is getting a data only sim possible on my existing account? And can I even replace the SIM card on the mini hub?  Thanks.
2 REPLIES 2
Message 2 of 3
Re: Data Only SIM for a mini hub
BT will have turned the mini hub off and only activate if you have problems with your broadband connection
Message 3 of 3
I get that but what I am asking is can I buy a Data only SIM and put it in and use it? Is it the sim that it came with that is deactivated or the hub itself?
