Black_Infinity
Message 1 of 3
Data Rate
DSL uptime:
5 Days, 0 Hours 50 Minutes 40 Seconds
Data rate:
4.94 kbps / 25.00 kbps
Maximum data rate:
4939 / 30238
Noise margin:
6 / 7.1
Line attenuation:
27.4
Above are my current figures. The 25.00 data rate never seems to change at all only the upload speed. The max data rate is always above 30000.
A few weeks back the noise margin was higher at 6/12 but the data rates did not change.
My question is , should the actual data rate be closer to the maximum considering the figures are stable.
Occasionally , the connection is reset ( usually during the night ) but everything always returns to how it is now ?
2 REPLIES 2
Webby
Message 2 of 3
Re: Data Rate
DLM seems to have banded your connection to a maximum of 25meg.
Until DLM feels your line can support a higher speed, the data rate is largely irrelevant.
Black_Infinity
Message 3 of 3
Re: Data Rate
Thanks for the reply. I'll give it time to see if anything changes.
My connection speed has been very stable recently. Maybe something will change in the future 🙂
