Message 11 of 12
Re: Data Speed and Max Data Speed Throttled at 20Mbps
Yes that's correct. It's Fibre 2 so I'm getting just under a third of the d/l speed. Up speed is as expected. Sorry, I probably didn't provide as much info as I should have in the o/p
Message 12 of 12
Lift and shift did the trick. Just wanted to say thank you as I’m not sure if they would have done it if I hadn’t pushed for it based on your suggestion. Really appreciate your taking the time to help. 😊
