Message 1 of 3
Dead spots
I live in an old house  with very thick walls, I have some rooms where I cannot get wifi, I have BT infinity.  I have been looking at
wi-fi home hotspot 500 kit  £99.99
wi-fi home hotspot 500 add-on £49.99
But I am not sure what I need to extend my wifi.
Also looking at the instructions for the hotspot 500 it says it must be plugged into a plug socket and not an extension, this is a problem as I do not have a spare mains plug socket only an extension.
Any advice would be useful.
Shirl
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Dead spots
Hi Shirl,
Powerline Adaptors might help. Take a look and let us know what you think.
Cheers
David
Message 3 of 3
Re: Dead spots
Thanks for the reply, but I bought a wifi adapter from Asda and that appears to have solved the problem.
