einzichi
Message 21 of 29
Re: Decreased my speed?
Resurrecting a dead topic...
So...I waited 5 days (more, considering it restarted again by itself) without turning off my router. There hasn't been any changes in speed at all, should I wait for the router or the server to change my speed or should I do something?
Message 22 of 29
as you now have a stbale connection I would contact the mods and ask for noise margin to be reset to 6db which will give you an increase in speed
contact mods
can take up to 3/5 working days for mods to contact you
did you ever remove the bellwire from terminal 3?
einzichi
Message 23 of 29
Ahh, I see, thanks!
Imma contact them now and see what happens..
No, I didn't do anything with the master socket. I was planning to but forgot about it and I got too busy.
Message 24 of 29
well I would get noise margin reset first as you have 5 days stable conenction and when that get fixed then look at removing the bellwire as with your attenuation and adsl2+ I would hope for about 14/15mb connection speed.
at present you are on adsl2 992.3 but maybe the bellwire removal may get you on to adsl2+ 992.5
einzichi
Message 25 of 29
Yeah, I'll wait for my noise margin reset first before doing anything and then I will consider removing the bellwire and hope that it helps my speed as well. Thanks!
Message 26 of 29
once your noise margin is reset then repost your stats and see if you can get help with increasing your speed
einzichi
Message 27 of 29
FINALLY! It's been 1 1/2 days since my line noise was reset to normal.
 everything is looking good so far...but my speed is only at 5.648Mbps... Snip7.PNG
I asked about it from the person who sent me an email saying that hey have reset my line noise and still no reply... (>_<)... Thank you everyone for the help, by the way.
Message 28 of 29
once your connection appears to be stable then check for the bellwire on terminal 2 and remove it if still there - should only be connections on terminals 2 & 5
Message 29 of 29
this link explains more about the bell wire http://www.filesaveas.com/jarviser/bellwirenutshell.html
