Shaptor
Message 1 of 12
Default gateway is not available
Recently began using a BT Extender instead of Wi-Fi to connect laptop computer to Home Hub 3. It works well most of the time, but, occasionally it drops the connection to the internet and after using the Network and Sharing Center in Windows 7, and trying to diagnose the problem, it comes up with ''Default gateway is not available''
Sometimes, of course, the problem seems to correct itself after a few minutes. But often I have to restart the computer, and reset the hub and it takes half an hour before I can get back online. Each time there seems to be no reason why everything stopped.
I have a Wi-Fi connected Android phone using the same hub and this NEVER has a problem.
Any ideas?
Smiley Frustrated
Tags (1)
11 REPLIES 11
Keith_Beddoe
Message 2 of 12
Re: Default gateway is not available
You could try this and see if it helps, as it applies to Vista, Win7 and 8.
Please check these network settings
Shaptor
Message 3 of 12
Thanks! Have done as you suggest, although why changing the wireless settings should cure a wired connection problem is beyond me. Will let you know if it cures the problem.
Smiley Surprised
Keith_Beddoe
Message 4 of 12
You need to do that on the wired interface as well. Just select the TCP properties for the local area network as well, just in case they are different.
Shaptor
Message 5 of 12
I did that too. But currently,after two hours of trouble free service it went down again. After rebooting and running all the desk top help and diagnostics it is still offline. Then suddenly its back again after 20 minutes.
Shaptor
Message 6 of 12
Here is the information from the diagnostics;
Network Adapter Publisher details
Issues found
The default gateway is not availableThe default gateway is not available
The default gateway is a device that connects a local network or computer to the Internet. A broadband modem or router is usually the default gateway. Not fixed Not Fixed
Investigate router or broadband modem issues Failed
Reset the "Local Area Connection" adapter Completed
Issues found Detection details
6 The default gateway is not available Not fixed Not Fixed
If you're connected to a hotspot or domain network, contact the network administrator. Otherwise: 1. Unplug or turn off the device. 2. After all the lights on the device are off, wait at least 10 seconds. 3. Turn the device on or plug it back into the power outlet. To restart a router or modem that has a built-in battery, press and quickly release the Reset button.
This can sometimes resolve an intermittent problem.
InformationalNetwork Diagnostics Log
File Name: D080484B-DBB8-470D-9CF0-43E631ACE065.Repair.1.etl
Detection details Expand
InformationalDiagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter Local Area Connection driver information:
Description . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Manufacturer . . . . . . . . . : Broadcom
Provider . . . . . . . . . . . : Microsoft Corporation
Version . . . . . . . . . . . : 11.22.0.2
Inf File Name . . . . . . . . . : C:\Windows\INF\netk57a.inf
Inf File Date . . . . . . . . . : 13 July 2009 20:37:26
Section Name . . . . . . . . . : DEV_KEY0.NTamd64.6.0
Hardware ID . . . . . . . . . . : pci\ven_14e4&dev_1698
Instance Status Flags . . . . . : 0x180200a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 6
Physical Media Type . . . . . . : 14
File Name: D080484B-DBB8-470D-9CF0-43E631ACE065.Diagnose.0.etl
InformationalOther Networking Configuration and Logs
File Name: NetworkConfiguration.cab
Collection information
Computer Name: IAN-PC
Windows Version: 6.1
Architecture: amd64
Time: Saturday, September 27, 2014 5:34:16 PM
Keith_Beddoe
Message 7 of 12
Try using manual network setting like this.
IP address 192.168.1.50
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.254
DNS Server 192.168.1.254
That will ensure that the default gateway can always be found.
Shaptor
Message 8 of 12
Thanks.  Have done as you suggest....
Keith_Beddoe
Message 9 of 12
Hopefully that will fix it. I think the issue is that the home hubs DHCP server, sometimes fails to respond to requests, especially if the internal table is full. The only way to clear this table is with a factory reset, which can be annoying if you have port forwarding rules set up.
Shaptor
Message 10 of 12
It was all going so well....
Then it stopped.  Ran diagnostics.  It said;
Issues found
DHCP is not enabled for "Local Area Connection Detected
Automatically update your network settings Completed
The connection between your access point, router, or cable modem and the Internet is broken
The network gateway is accessible, but Windows couldn’t receive network traffic from the Internet. Detected
Your broadband modem is experiencing connectivity issues Not run
The system reset my IP address and reconnected DHCP.
So I reset the hub, and it is now working. The saga continues...
Smiley Frustrated
