tateandsmile
Message 1 of 6
Delivery of Items
Is it normal for you to receive your home hub and youview box on the day it's supposed to be installed? Had my order confirmed today and these items are said to be delivered on my install date. What if they're not there in time?
5 REPLIES 5
Guru
Message 2 of 6
Re: Delivery of Items
They normally arrive before the installation date.
tateandsmile
Message 3 of 6
Even though it says it will be delivered on the day of installation?
Guru
Message 4 of 6
Yes, my daughters did.
tateandsmile
Message 5 of 6
Thanks. I'll have to keep an eye out for them then.
MEM
Message 6 of 6
Mine were due to arrive tomorrow but landed this morning. All set up and waiting for BT Vision to be activated some time tomorrow now.
