Message 1 of 6
Deregister handset bt3570
Hi, I can't deregister the faulty handset from the base and I can't register my new handset until the faulty one has been deregistered? Help!
5 REPLIES 5
Message 2 of 6
Re: Deregister handset bt3570
Hi @Peterhill87   You could try the product helpdesk (when they are open)
Product helpdesk information
If your phone is within warranty:
By phone: 0800 145 6789
Monday to Friday 9.00am to 5.30pm, Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
Message 3 of 6
Hi @Peterhill87
Welcome and thanks for posting!
Sorry you're having problems with the handsets.  Your best bet would be to chat with product support using the contact details above.  Thanks @VeteranISPUser  Smiley Happy
Cheers,
Robbie
Message 4 of 6
Hi, many thanks for your prompt reply, after trying various solutions I contacted support who directed me to a premium number.
Message 5 of 6
After a lot of head scratching I tried one of the other working handsets and I was able to deregister the faulty handset from there.
The new handset had problems registering with the main base, but after a few hours I tried pressing the find button on the base unit until the blue button was flashing (registering mode not obvious in the instructions) and then registered the handset, phew!!
Message 6 of 6
Great post there @VeteranISPUser . Kudos to you Smiley Wink
Glad to hear that sorted everything for you @Peterhill87 . Post back if you have any other problems.
Cheers
David
