Message 11 of 13
Re: Descrepancy between Home hub usage data and Broadband Monitor
Thank you for your useful advise. I will have ago at you suggestions. As advised, I have Home Hub 4 and using ADSL broadband.
Would you agree though the hub is showing the most recent usage and the monitor lags behind. As I mentioned earlier, I have had stable connection as shown by the hub for 14 days now.
Recognised Expert
Message 12 of 13
The information you have given is not consistent as you have noted.  The question is why ?
We need to establish a sensible start point and start comparing what the Hub is recording and what the usage monitor states. I suggest you take a screen print of the Hub data screen now. Record the monitor usage for midnight to-night that should be available around midday to-morrow. This gives you a baseline from which to measure usage from to-morrow onwards.
Message 13 of 13
Thanks. Started a log as suggested and I will report back end of the month on my findings.
