normanmclean
Message 1 of 5
Desktop Not Picking Up Network after HH Change.
I have 2 laptops and a desktop on my network. A few months ago I got a HH2, after that was installed my desktop would not pick up my network allthough all my other devices including wifi radios, Wii and iPhone are fine.
As I don't use the desktop now I didn't worry too much about it but I am about to sell the desptop so would like to make sure it works ok before selling. I can pick up next doors network and my FON connection too so I am guessing it must be a Home Hub issue as tihs only happened after the changeover.
4 REPLIES 4
Message 2 of 5
Re: Desktop Not Picking Up Network after HH Change.
try changing the wireless from default b/g/n to just b/g.   if that works and solvesyour connection problem then you can always change it back after selling the desktop
normanmclean
Message 3 of 5
Thanks but pardon my ignorance but how do I do that? Looked in the Hub Manager but can't find it.
Message 4 of 5
if you enter the hub manager then it should be under the wireless heading  should be the default b/g/n and then select just b/g
normanmclean
Message 5 of 5
Thanks, made the change and it picks up fine now. Cheers again, much appreciated.
