Message 1 of 4
Desktop not connecting to BT router
Hello,
I have the new BT router and can access it from the laptop and other wireless items in my home.
I do however have it hardwired to my desktop but I cannot get it connected. When I run the disk and it comes to the 'connecting to your hub' page, it always comes back, not connected.
Any ides? The strange thing is that when I go to Internet explorer, it does connect for a minute before shutting down by itself.
Dave
3 REPLIES 3
Message 2 of 4
Re: Desktop not connecting to BT router
hi to start with uninstall the disc it is not needed and can cause more problems then it cures
also check your network cards drivers using the manufactures web site not windows updates
Message 3 of 4
I had similar problem with my laptop... was trying out the ethernet as there was some wifi problem on the router.  All i did was restart and then disable and enable the network card and it has worked fine.
Hope this helps.
Message 4 of 4
ok,
I've uninstalled the disk.
I've just moved home and the internet worked hardwired to the router there ok.
How do I check the network cards? What should I be looking for?
