paulmclem
Message 1 of 3
Device Disconnections
Hi,
I've seen a few posts relating to devices being disconnected from people's home networks, but I'm not sure if I've seen the solution. In our case we have been with BT since April (after 14 trouble free years with Sky) and the following is an example of what happens frequently on our network:
08:34:02, 01 Dec.Device Connected: 192.168.1.163, 18:cf:5e:c6:20:73, ASGA54743
08:32:58, 01 Dec.admin login success from 192.168.1.198
08:32:10, 01 Dec.Device Disconnected: 192.168.1.163, 18:cf:5e:c6:20:73, ASGA54743
PC I am working on (ASGA54743) is disconnected from the network and therefore loses internet connectivity. Almost 2 minutes later it decides to reconnect. As a home worker this is particularly annoying as I can be in the middle of something and for no apparent reason I am disconnected. At the same time my other PC, phone etc are still connected without issue. However, they will probably be disconnected another time when my work PC is ok. So annoying.
Here is our Hub crib sheet:
1. Product Name: HomeHub4 2. Serial number: +076281+1603007427 3. Firmware version: v0.07.03.30329-BT (Type B) Last updated 5/7/2016 4. Board version: 01A 5. DSL uptime: 1 days, 17:01:04 6. Data Rate: 1219 / 20019 7. Maximum Data Rate: 1159 / 20896 8. Noise Margin: 7.7 / 3.1 9. Line Attenuation: 11.7 / 17.5 10. Signal Attenuation: 11.4 / 22.6 11. Data sent/received: 270.8 MB / 5.4 GB 12. Broadband username: bthomehub@btbroadband.com 13. BT Wi-fi: Yes 14. 2.4GHz wireless network/SSID: BTHub4-S6G8 15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s)) 16. 2.4GHz wireless security: WPA & WPA2 (Recommended) 17. 2.4GHz wireless channel: Automatic (Smart Wireless) 18. 5GHz wireless network/SSID: BTHub4-S6G8 19. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s)) 20. 5GHz wireless security: WPA2 Only 21. 5GHz wireless channel: Automatic (Smart Wireless) 22. Firewall: Default 23. MAC Address: a8:d3:f7:c8:33:62 24. VPI/VCI: 0/38 25. Modulation: G.992.5(ADSL2+) 26. Latency type: Interleaved 27. Software variant: - 28. Boot loader: 0.5.0-BT (Wed Nov 12 11:47:59 2014)
Is there any permanent fix to disconnections? At the moment we are seriously giving consideration to leaving BT when our contract expires. This isn't helping their cause.
Cheers,
PaulC.
2 REPLIES 2
john46
Message 2 of 3
Re: Device Disconnections
are you using a wired or wireless connection
paulmclem
Message 3 of 3
Was wireless today, but it doesn't seem to make much differemce i.e. happens if I'm using a cable or not.
