Message 1 of 5
Difference between BT player and the BT TV button
When I press on BT Tv i get a different set of options than when using the BT player button in the youview menu.
Specifically the catch up only appears when I select within the on demand players menu
Bug or feature??
4 REPLIES 4
BT Sport Expert
Message 2 of 5
Re: Difference between BT player and the BT TV button
Hi, when you say press BT TV, do you mean the dedicated button on the remote?
Message 3 of 5
BT TV is one option on the youview menu bar
The button on the remote sends you to BT player (option in the on demand players)
So my question is why do I get catch up only when I go to the player, bug or feature?
Message 4 of 5
Edit after launching the application the swcpnd time the catch up option appeared on BT TV
BT Sport Expert
Message 5 of 5
ok great,
lauching from either dedicated BT Player button or from within youView menu should launch the same app and give same options
