MaximusPrime
Message 1 of 12
Different Router == Better speeds?
Hi,
I've been told if I switch to a Netgear Router from HHB5 I'll get better broadband speed - any truth in this?
11 REPLIES 11
gg30340
Message 2 of 12
Re: Different Router == Better speeds?
An impossible question to answer.
MaximusPrime
Message 3 of 12
Care to ellaborate? 🙂
gg30340
Message 4 of 12
You might get 1 or 2 Mbps then again you might lose 1 or 2 Mbps. It is impossible to say and anybody who says you will get better speeds is just guessing.
licquorice
Message 5 of 12
Borrow one and try it to see.
MaximusPrime
Message 6 of 12
I dunno any1 with a VDSL modem, wondering if any1 has had success or failure trying other brands?
Webby
Message 7 of 12
Some lines do perform better with routers that use different chipsets. Broadcom chipsets seem to be quite highly talked of.
MaximusPrime
Message 8 of 12
Any particular Broadcom router that springs to mind?
licquorice
Message 9 of 12
You could always 'borrow' one from Amazon.
gg30340
Message 10 of 12
As was pointed out to you on your previous thread
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Line-monitoring-tools/td-p/1545441
the only sure way that you will be able to get better speeds on your line is to move your house nearer the cabinet.
