Roblevelo
Message 1 of 4
Diffferent speeds on two computers
I have two identical laptops albeit with some differences in the software installed. Same antivirus installed on each. One gives 40Mb/s download, the other 15Mb/s. Speed tests using the same cable directly into the router.
Anyone any ideas what this may be please?
3 REPLIES 3
johngardner42
Message 2 of 4
Re: Diffferent speeds on two computers
Same OS on both machines?
Assuming you'r using Windows use msconfig to see what is loading on boot and duplicate start up programmes on both machines, and see if this corrects the variation in broadband speed.
Roblevelo
Message 3 of 4
Same OS, will check msconfigs.
john46
Message 4 of 4
are all drivers up to date using the manufacturer's web sites not windows updates
