Message 1 of 4
Digital Voice phone ceased to ring.
My Digital Phone handset has ceased to ring, it did for several months after installation. No keypad tones either.  I have reset phone and re-registered it. I have rebooted the hub. I tested it with Ringback and also using Home Hub phone finder, no sound. Any one got any ideas?
3 REPLIES 3
Message 2 of 4
Re: Digital Voice phone ceased to ring.
Hi @Joncbro   How did you reset the phone, did you pull the batteries out?
Message 3 of 4
No, I used the phone reset in the menu. I'll try the battery removal method.
Message 4 of 4
No. removing and re-inserting the batteries made no difference.
