Message 11 of 411
Re: Digital Voice with different Router
I would first check to see if your property is classified by BT as Brownfield or Greenfield. If its the former they will give you Fibre but not Digital Voice (just happened for me). Brownfield sites get a mandatory copper landline for phone calls
Message 12 of 411
Brownfield sites would normally have an existing copper infrastructure, so it makes sense to use it, rather than go to the trouble of providing Digital Voice at the moment.
Message 13 of 411
In my case I do not have a copper line - always been on Virgin - BT would have to install a new copper line, rather than just activate DV. How stupid is that?
Message 14 of 411
I would expect BT to provide more guidance because in our area  they have monopoly of the provision of fibre and should show more consideration of customer preferences. The guidance provided by choppyc was generic, not specific to his/her router and would be relevant to many customers.
Message 15 of 411
BT provide a broadband service and a means to utilise that service. If you require something different, it is not incumbent upon BT to detail how that can be achieved.
BT do not have a monopoly anywhere.
The fibre network is provided by Openreach, not BT and is available to all providers.
Message 16 of 411
Thanks for confirming the roles of BT and Openreach. Although BT was my preference for fibre broadband, I did look for alternative suppliers using the Openreach fibre as you suggest. However, after having 'nothing for your location' responses from SSE, Shell Energy, EE, Now Broadband, TalkTalk, Plusnet and Vodafone, I reverted to BT. The reality out here is that there is hardly any choice, for whatever reason.
I used Online Chat with BT and actually signed up during  the Chat because the agent said they would be able to supply a Master Socket and a splitter that would enable me to use my current BT phone.  I also had email dialog confirming I could use my Netgear router for internet connection, with full context of my account.
When  the Openreach guy arrived to hook it up, he dismissed the Master Socket I'd been sent as obsolete, and when I showed him the Chat transcript he said the agent didn't know what they were talking about. He also had not  been made aware of the email dialog I'd had with BT confirming ability to use my Netgear stuff.
So I was left with the opposite of what I'd been led to expect.
The connections between Openreach and BT seem ropey; I had texts hours after Openreach had left, telling me he would be there shortly.
I appreciate this is off topic relative to me wanting something different from BT's standard offering, I'm just an unhappy customer.
Message 17 of 411
Hello jamestrever.  Did you attempt to replicate the configuration that works for choppyc? I'm plucking up the courage to give it a shot and would welcome any guidance from anywhere...
Thanks.
Message 18 of 411
A couple of points.
Although it would incur extra cost, you could always use your Netgear router and a third party VoIP provider rather than BT digital voice.
Other ISPs choose not to offer FTTP for whatever reason rather than it is not available to them.
Message 19 of 411
Thanks liquorice, I'll check that out. We just didn't want to lose our landline number. Yes, understood it's the ISPs choosing not to play. It's why we had to move from Plusnet after about 20 years.
Message 20 of 411
hi, im having issues setting this up like you explained. im connected but certain sites will not load (imn guessing dns issue)
you said that you need to connect router to smart hub via lan cable, but which do i connect the wan cable from the fibre box to? do i connect it to the smart hub or to my third party router? thanks
