Message 111 of 411
Re: Digital Voice with different Router
The adapter connects to SH2 using DECT not wifi. You need the SH2 connected to the main connection to get DV as it is the dect base station
Message 112 of 411
@licquoricewrote:
Digital voice requires the use of the SH2 to work. End of.
The adapter doesn't connect by wifi it connects via DECT, the WPS button is dual function.
Surely the phones connect to the adaptor via DECT and the adaptor connects to the router via wifi?  Otherwise what is the point?  It would mean the SH2 is even more antiquated than I thought when I ditched it.  If I have to configure it as a dumb proxy just to connect the phones then I guess I will - but only for as long as it takes to get a more up to date provider.
Message 113 of 411
This I find very disturbing.  The annoying thing is that when I signed up to use the BT service I made it clear that I could not use their SH2 and then fell for the "Oh it will be fine" line.  I should have known better. Now I have a service where the phones are about to be disconnected.
Does the SH2 *have* to be connected to the ONT or does it just need to connected to the internet?
Message 114 of 411
I wish this facility wouldn't keep putting my posts up twice!
Message 115 of 411
It has to be connected to the ONT
Message 116 of 411
Sh2 needs to be connected to ONT
Message 117 of 411
No, the phones connect to the adapter physically and the adapter connects to the hub via DECT.
The adapter is just a pseudo analogue phone socket.
Message 118 of 411
So the only option is to disable DHCP etc and have it act as a dumb pass-through for the UDM?  I feel a bit nauseous.
Message 119 of 411
It won't be a 'dumb passthrough' it will still be routing and natting.The SH2 doesn't have a bridge mode.
Message 120 of 411
So the old hack to get to the hidden menu that enables bridge mode is no longer available on the SH2?  My day is getting better and better 😞
