Message 1 of 5
Digital voice one call on 2 handsets
How do I enable picking up of an existing call on another handset. At the moment if a call is on one handset the other handset has dial tone which can be used to make a second call apparently.
4 REPLIES 4
Message 2 of 5
Re: Digital voice one call on 2 handsets
this may help  looks like only see option when you are on a call
https://www.bt.com/help/landline/digital-voice--how-do-i-use-my-calling-features-
Message 3 of 5
Not sure what you meant. I tried to set up a 3 way call back to the home phone line but it did not work. Mobile call to home phone number then 3 way call option on Alexa phone to call home phone number to be picked up by conventional phone connected to smart hub phone port. Is there not a way to parallel all phones on digital voice in the way that all phones on extension wiring are paralleled?
Message 4 of 5
you could try going to phone settings/line settings/call settings and change call mode to single   do you have auto join calls 'on'
Message 5 of 5
Hi, Thanks for looking at this question.
I have discovered that if I select single call and auto join calls under phone settings line settings call settings you can get 2 handsets on the same call as long as they are both connected to the smart hub. This also works if you select multi call but you then have to select join call when call in progress. This doesn’t seem to work with hard wired phones connected to the smart hub phone port. A call made from a hard wired phone does bring up the option to join call on the Alexa handset but selecting it does not connect and gives 2 bleeps.
Alan
