Message 1 of 9
Dire Infinity speeds
I was watching film 4 on the 4 on demand website when it cut out because there was insufficent bandwidth. I restarted thought nothing of it then it did it again. I've so far done 3 non-bt speed test all of them are coming in under 10mb. I should be getting 75. I've done 3 bt speed tester tests and am getting the same but I can't do the test with the speedtester email address because it times out and doesn't load. I followed all the instructions, switched off anti-virus etc, restarted modem/router but the speed remains around 10mb: http://192.168.1.254/html/troubles/event_log.html I've checked the status, there seems to be no problems in my area.
Also done the glasnost test on streaming video (see below). Any suggestions on how to resolve this? I am using an ethernet cable to connnect to the router.
All FlashVideo and control flow transfers using port 8080
Transfer Direction Bandwidth FlashVideo flow Bandwidth control flow
Download #17726 Kbps8701 Kbps
Download #27806 Kbps8889 Kbps
Download #37414 Kbps8820 Kbps
Upload #14147 Kbps4001 Kbps
Upload #24110 Kbps4108 Kbps
Upload #34217 Kbps4088 Kbps
All FlashVideo and control flow transfers using port 41846
Download #18709 Kbps7366 Kbps
Download #27448 Kbps7151 Kbps
Download #38836 Kbps7133 Kbps
Upload #14095 Kbps4112 Kbps
Upload #24171 Kbps4190 Kbps
Upload #34110 Kbps4099 Kbps
FlashVideo transfers using port 8080 and port 41846
Transfer Direction Bandwidth Port 8080 Bandwidth Port 41846
Download #17726 Kbps8709 Kbps
Download #27806 Kbps7448 Kbps
Download #37414 Kbps8836 Kbps
Upload #14147 Kbps4095 Kbps
Upload #24110 Kbps4171 Kbps
Upload #34217 Kbps4110 Kbps
Control flow transfers using port 8080 and port 41846
Download #18701 Kbps7366 Kbps
Download #28889 Kbps7151 Kbps
Download #38820 Kbps7133 Kbps
Upload #14001 Kbps4112 Kbps
Upload #24108 Kbps4190 Kbps
Upload #34088 Kbps4099 Kbps
8 REPLIES 8
Sage
Message 2 of 9
Re: Dire Infinity speeds
Do a speedtes here, click on further diagnostics once the first test has finished and post the full results of the second test.
Message 3 of 9
I did that three times, I can't do the third part of the test. I used the BT Chat thing and they told me to call tech support if it wasn't resolved in a few days. Few days later I'm back to watching Channel 4 online and low and behold it keeps cutting out.
Tried calling tech support but they're apparently very busy but could hold my call in the queue for me.
Tried to run the second part of the diagostic test - it crashed out for me - told me I needed to log in as speed test domain. When I log in as speedtest domain it can't find the page. I tried again and now I'm getting error #2032.
I can't do part 2 of the test keeps telling me to log in as speedtester but speedtester either doesn't load or gives me an error message. This is the second part of the test I did on sunday. I have to assume this is the same because the speeds are the same.btspeed2.JPG
Moderator
Moderator
Message 4 of 9
Hi lostof,
Thanks for posting. It looks like we'll need to take closer look at this for you. Drop me an email with the details. You'll get the 'contact us' link in the about me section of my profile.
Cheers
David
Message 5 of 9
Yeah so I used the contact us form - the only one I could see both in IE and firefox is the one that is visible above the forums. Appears to go to the India call centre - at the second attempt. Have told me there is nothing wrong with my speed. I should schedule my self for chat with them if I'm still having a problem. Oh and my person favourite I'm obviously using wireless... this is despite me filling in a form to say the reverse is true.
Sage
Message 6 of 9
Did you go into DavidM's profile for the link?
Message 7 of 9
Yes, I clicked. There is no contact us form other than the main one.
Message 8 of 9
Moderator
Moderator
Message 9 of 9
Hi lostof
I'm really sorry about that, you should now be able to see the link the 'contact the mods' link in my forum profile under the 'about me' section. You can find the link by clicking on my username.
Neil
