Mikecat
Message 1 of 2
Direct fed from exchanges
I am sure there are a lot of people who visit this site and see the phrase "Direct fed" and do not understand what it meanas and why they cannot yet have infinity.
Please can you confirm
What "Directly fed from the exchange" actually means
Why they cannot yet have BT Infinity and if there are plans to replace directly fed cables to an exchange area with fibre to the cabinet
"Bother" said Pooh as his bungee cord broke
1 REPLY 1
Aarong
Guru
Message 2 of 2
Re: Direct fed from exchanges
Directly fed means you are not attached to any local green cabinet, your are directly fed from the exchange itself, hence why you can't have FTTC (Fibre to the Cabinet).
However, the good thing is that and when it's available you would be piped up with FTTP (Fibre to the Premises) which is a lot better and steadier than most FTTC connections will provide, including better ping rates, speeds etc.
Since the Infinity rollout is mainly concentrated on the FTTC rollout, people who are directly fed won't see any speed differences for a while.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
