chrishanson
Message 1 of 3
Disabling broadcast SSID on home hub 5
is there a way to disable broadcast SSID with the home hub 5 manager? All I can find is an option to turn off wifi all together which is not what I want
thanks
Tags (3)
2 REPLIES 2
Jonkarra
Expert
Message 2 of 3
Re: Disabling broadcast SSID on home hub 5
Doesn't appear to be an option on the HH5. I wouldnt bother though as apps that detect wireless networks which arent broadcasting SSID are easy to find.
Ectophile
Distinguished Guru
Message 3 of 3
It's not an option on the Home Hubs.  It just makes it harder to connect, while providing little security.
