john46
Message 11 of 24
Re: Disconnection issues and extremely slow speeds
The link looks like this
XRaySpeX
Recognised Expert
Message 12 of 24
What are your full router stats now? Your original ones indicated you had been placed on a banded profile in response to past errors on your line. Your line is capable of about 6 Meg Sync speed but you were only getting 357 K. You were not being artificially limited by the IP Profile. The IPP is derived from the Sync speed & is usually 88.2% of it. Yours is exactly right. It's the Sync speed that is being artificially limited by the DLM. You need to call your ISP to reset the DLM in order to remove any banding.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
john46
Message 13 of 24
the mods are already involved with this posters problem there is no need to call the help desk at all
XRaySpeX
Recognised Expert
Message 14 of 24
@john46: Oh, isn't this a user Community? Aren't users allowed to offer advice from their knowledge to help other users? I thought that was the idea. Aren't forums meant to bring many varied ideas & backgrounds to bear on the same problem?
I feel I'm being warned off Smiley Frustrated!
john46
Message 15 of 24
not at all just read through the posts first you will see that this thread is in the mods hands and using the helpdesk will only cause more confusion then is needed
NeilO
Moderator
Moderator
Message 16 of 24
@DariusA I tried calling there but missed you, I wanted to let you know that I've reset the profile so hopefully you'll see an improvement shortly. Please post back and let me know if that has helped?
DariusA
Message 17 of 24
Sorry, was in a no signal zone! I've waited a few hours but it actually seems worse than before.
NeilO
Moderator
Moderator
Message 18 of 24
@DariusA I called again and left you a voice mail there, my checks are showing a potential loop fault and when I've called the landline it is constantly giving me an engaged tone. We need to ensure this is not being caused by extension wiring or something that's connected to the line.
Can you try a phone in the test socket to see if you can get a dial tone and make a call? You can get to the test socket by removing the faceplate cover as shown in the picture below.
DariusA
Message 19 of 24
@NeilOWe don't normally use the landline at all so it's not usually connected - don't know if that would be a problem! I have plugged it directly into the test socket, got a dial tone and made a call with no problems.
NeilO
Moderator
Moderator
Message 20 of 24
@DariusA It does no harm to have a phone connected and use it occasionally as the electric current can help prevent joins on the line from oxidising. If its working ok in the test socket and not when it is plugged into the normal socket then that would indicate an internal wiring issue.
Would you be able to connect the Hub with a filter to the test socket and leave it overnight and I'll run further checks in the morning?
