DariusA
Message 21 of 24
Re: Disconnection issues and extremely slow speeds
@NeilO  I've connected the hub to the test socket with a filter as requested. It already seems to be faster so I'm assuming that indicates a problem with the main socket itself? Will wait to see what the checks suggest after I leave it overnight.
XRaySpeX
Recognised Expert
Message 22 of 24
What are your full router stats now?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
NeilO
Moderator
Moderator
Message 23 of 24
@DariusA I've checked your connection stats again this morning and everything looks good since you've connected to the test socket.
DariusA
Message 24 of 24
@NeilOThat's great, thanks Neil - things seem to have been running well and we can stream normally again so it certainly all seems good. Thanks again for your help.
