Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hi there,
I've been on infinity since October time and got the HH5. However, I've been receiving disconnects recently from the Internet while still connected to the router. I'm still connected to the router via wifi or ethernet but the WAN just drops. ANd it takes a little bit to reboot. I assume it must be to do with the line from the cabinet to the house.
Here is a typical log of the WAN when it goes down (it went down twice in this perioid) -
23:40:11, 13 Feb. | ( 116.150000) WAN operating mode is VDSL |
23:40:11, 13 Feb. | ( 116.150000) Last WAN operating mode was VDSL |
23:40:09, 13 Feb. | ( 114.440000) PPP IPCP Receive Configuration ACK |
23:40:09, 13 Feb. | ( 114.440000) PPP IPCP Send Configuration Request |
23:40:09, 13 Feb. | ( 114.430000) PPP IPCP Receive Configuration NAK |
23:40:09, 13 Feb. | ( 114.430000) PPP IPCP Send Configuration ACK |
23:40:09, 13 Feb. | ( 114.430000) PPP IPCP Receive Configuration Request |
23:40:09, 13 Feb. | ( 114.420000) PPP IPCP Send Configuration Request |
23:40:08, 13 Feb. | ( 113.150000) PPPoE is up - Down Rate=39993000Kbps, Up Rate=9995000Kbps; SNR Margin Down=18.8dB, Up=13.0dB |
23:40:08, 13 Feb. | ( 113.140000) CHAP authentication successful |
23:40:05, 13 Feb. | ( 110.000000) CHAP Receive Challenge |
23:40:05, 13 Feb. | ( 110.000000) Starting CHAP authentication with peer |
23:40:05, 13 Feb. | ( 110.000000) PPP LCP Receive Configuration ACK |
23:40:05, 13 Feb. | ( 109.990000) PPP LCP Send Configuration Request |
23:40:05, 13 Feb. | ( 109.990000) PPP LCP Receive Configuration Reject |
23:40:05, 13 Feb. | ( 109.980000) PPP LCP Send Configuration ACK |
23:40:05, 13 Feb. | ( 109.980000) PPP LCP Receive Configuration Request |
23:40:05, 13 Feb. | ( 109.980000) PPP LCP Send Configuration Request |
23:39:50, 13 Feb. | ( 95.430000) PTM over DSL is up |
23:38:57, 13 Feb. | ( 41.990000) WAN Auto-sensing running. |
23:34:37, 12 Feb. | ( 105.410000) WAN operating mode is VDSL |
23:34:37, 12 Feb. | ( 105.410000) Last WAN operating mode was VDSL |
23:34:35, 12 Feb. | ( 104.050000) PPP IPCP Receive Configuration ACK |
23:34:35, 12 Feb. | ( 104.040000) PPP IPCP Send Configuration Request |
23:34:35, 12 Feb. | ( 104.030000) PPP IPCP Receive Configuration NAK |
23:34:35, 12 Feb. | ( 104.030000) PPP IPCP Send Configuration ACK |
23:34:35, 12 Feb. | ( 104.030000) PPP IPCP Receive Configuration Request |
23:34:35, 12 Feb. | ( 104.020000) PPP IPCP Send Configuration Request |
23:34:34, 12 Feb. | ( 102.820000) PPPoE is up - Down Rate=39993000Kbps, Up Rate=9995000Kbps; SNR Margin Down=18.6dB, Up=12.7dB |
23:34:34, 12 Feb. | ( 102.800000) CHAP authentication successful |
23:34:34, 12 Feb. | ( 102.700000) CHAP Receive Challenge |
23:34:34, 12 Feb. | ( 102.700000) Starting CHAP authentication with peer |
23:34:34, 12 Feb. | ( 102.700000) PPP LCP Receive Configuration ACK |
23:34:34, 12 Feb. | ( 102.690000) PPP LCP Send Configuration Request |
23:34:34, 12 Feb. | ( 102.680000) PPP LCP Receive Configuration Reject |
23:34:34, 12 Feb. | ( 102.680000) PPP LCP Send Configuration ACK |
23:34:34, 12 Feb. | ( 102.680000) PPP LCP Receive Configuration Request |
23:34:34, 12 Feb. | ( 102.680000) PPP LCP Send Configuration Request |
23:34:15, 12 Feb. | ( 84.010000) PTM over DSL is up |
23:33:31, 12 Feb. | ( 39.600000) WAN Auto-sensing running. |
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
Here it is :
1. Product name: | BT Home Hub |
2. Serial number: | +068543+NQ42541040 |
3. Firmware version: | Software version 4.7.5.1.83.8.204 (Type A) Last updated 20/01/15 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 00:50:56 |
6. Data rate: | 9995 / 39993 |
7. Maximum data rate: | 20033 / 77577 |
8. Noise margin: | 13.0 / 18.7 |
9. Line attenuation: | 23.1 / 20.0 |
10. Signal attenuation: | 22.9 / 19.7 |
11. Data sent/received: | 36.8 MB / 980.4 MB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | Yes |
@fusionet24 wrote:Here it is :
3. Firmware version: Software version 4.7.5.1.83.8.204 (Type A) Last updated 20/01/15
There are many reports of exactly what you're seeing as a result of the latest firmware upgrade.
Now, I don't have a problem but many people do.
The quick fix is to get an Openreach modem at auction and use that to front-end the Homehub, or a better fix is to buy a different modem-router entirely like the TP Link TD W9980 for example
SD077
If you have a white Openreach modem you can use the Homehub 4. If no Openreach modem it is the Homeub 5 you need.
@SDO77 wrote:
Hi, I've got infinity and for the last several months same issue. BT sent out a new hub but service is slower and keeps switching connection. Upon reading this a) glad it's not just me b) think they've sent wrong hub - it's a 4 but reading here and on bt homepage anyone who is on infinity should have "5" hub. Guess back on the phone to them..... More time on phone with them than on Internet......
So you have a Homehub4 and an OR modem and you're having the same issue as with the Homehub5, but you want a Homehub5 ?
Are you sure?
What about the fix of rolling back to previous firmware or BT not shipping firmware that kicks out a lot of users 😛
Is it possible to roll back firmware?
