hbro1095
Message 1 of 6
Dlink & Wireless Help
Hello, I'm goign to cut a long story short and say thank you now for taking your time reading this..
I've just bought a summer house and the wireless from the house is not good enough, I just purchased some netgear things, you plug them int he power and it gives you a internet connect through the other port
(http://www.littlewoods.com/powerline-av200-ultra-adapter-kit-xavb2001/926711994.prd?browseToken=%2fb...)
Now the connect is perfect on the playstation and PC its so quick but I woudl now some how like to put a router out there so I can use the pc and ps3 at the same time, i also have a iphone 4 so that is going to need it. I have purchased a bt home home, same one as I have indoors but how will I put a connection it? The cable running off the netgear plug thing is a ethernet cable..
Please help, im so close!
- Hayden
5 REPLIES 5
Message 2 of 6
Re: Dlink & Wireless Help
this may help  http://www.jarviser.co.uk/jarviser/repeaterhubswired.html
hbro1095
Message 3 of 6
Thanks for the reply, thats what i want to do more or less but the lead i was given as default is a ethernet to ethernet but it needs to be an ethernet to the broadband socket to get a connection.
Message 4 of 6
would it not be the ethernet to ethernet as connection to 2nd hub would be etherent not modem cable
hbro1095
Message 5 of 6
Thats what I thought it woud have been, it dontchange when i put it in any other the 4 enthernet ports. Not connection or change in lights.
hbro1095
Message 6 of 6
I've been trying some thing around and I've reset the main bt home hub to the default settings and once I connect the 2nd one via enthernet it then diconnects the main line and just says connection problem. Maybe a setting in the home hub panel?
