Message 1 of 83
Do BT Throttle Internet Connections?
The reason I ask this is because lately I have noticed that my Broadband speed goes down from a consistant 8 meg speed to a crawl during peak hours.  Obviously can't give you a test result at the moment but I thought I would ask this and then post my speeds later on this evening.
82 REPLIES 82
Message 2 of 83
Re: Do BT Throttle Internet Connections?
Thought it might be a good idea to do a test now and give you my hub stats and then post them again later. ADSL Line Status
Connection information
Line state: Connected
Connection time: 9 days, 19:18:11
Downstream: 8,128 Kbps
Upstream: 448 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Fast
Noise margin (Down/Up): 12.4 dB / 24.0 dB
Line attenuation (Down/Up): 13.5 dB / 7.5 dB
Output power (Down/Up): 19.8 dBm / 11.6 dBm
FEC Events (Down/Up): 0 / 1
CRC Events (Down/Up): 127 / 117
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
HEC Errors (Down/Up): 280 / 53
Error Seconds (Local/Remote): 0 / 0
The speed coming into your house
The speed you get at your computer
Connection speed 8.13Mb
Good
Download speed
6.26Mb
Upload speed
0.38Mb
Go
Message 3 of 83
BT manage p2p during peak ours unless you are on the totally unlimited contract taken out since feb 2013  run glasnost test and that will tell you if you are being managed http://broadband.mpi-sws.org/transparency/bttest.php
Message 4 of 83
I'm not using P2P BBC Iplayer for example with go down to 64KBs or lower for example.
The software doesnt seem to want to run on my PC 😞 Got Java installed and click run and it says there is an error
Message 5 of 83
there have been post saying there is a problem with the recent java update.
if it is bbc iplayer then bt will not restrict your speed - only p2p restricted from 4pm to 11pm and all weekend
Message 6 of 83
Just seems a bit weird there is only a problem during those hours.  So was just wondering if anyone else had a similar problem and whether there was a solution
Message 7 of 83
this could be exchange congestion - is there anything shown here for your exchange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
I have not read any posts suggesting BT are restricting BBC iplayer at peak times - there would be an outcry if that happened
Message 8 of 83
No no problems will check at peak times and get back to you with speeds etc.  Thanks for your help so far
Message 9 of 83
no problem  can you run btspeedtester just now when ok as a reference point for later
btspeedtester
Message 10 of 83
Wouldn't let me copy and paste so just did a screen shot
