Distinguished Guru
Message 11 of 52
Re: Do BT tell Lies ?
That's not your IP profile. Up should be either 10 or 20.
If not, I'll try again 🙂
Message 12 of 52
Don`t know mate i am just one of the ignorant masses who trust the information they are given before the sale.You expect the right size engine when you buy a car.I was told 56mbps not the up to bo...cks
Message 13 of 52
Down-Up 37.56/8.14
ping 29.88
ok but profile for these speeds
matches
Distinguished Guru
Message 14 of 52
Sorry if I confused you. You need to find your IP profile to see if you're on the correct package. If you're on 40/10, you obviously won't ever hit 56Mbps.
You do the speedtest at http://speedtest.btwholesale.com then you do the Further Diagnostics. Then it should tell you your IP profile.
Message 15 of 52
Thanks to those who replied,i just admit defeat.Have seen BT true colors
Message 16 of 52
Here you go Ray,no hope for me
Download speedachieved during the test was - 37.59 Mbps
 For your connection, the acceptable range of speedsis 16 Mbps-38.4 Mbps .
 Additional Information:
 IP Profile for your line is - 38.4 Mbps
Upload speed achieved during the test was - 8.07Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Distinguished Guru
Message 17 of 52
That's right, you're getting the maximum you can 😞 😉
Message 18 of 52
Yes shame they fooled me into thinking it would be 56mbps.
Seems dishonest practice to me.
Distinguished Guru
Message 19 of 52
I'm not sure the extra speed would have made any difference to your connection.
Message 20 of 52
Yeah, same here:
I was promised 52.5 MBPS and i get around 30MBPS if im lucky
so Bt do tell lies
