Message 1 of 2
Do my stats look ok for my speed?
Hi,  Just got Infinity 2 installed a few days ago.  I was quoted on getting a estimate of 79-80mb down, but I am only connected at 65.83mb down/19.53mb up
Do my stats look ok for my speed?  Why is my Max down rate only 68417, where I see other people with over 100000?
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 07/05/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 09:35:09
6. Data rate:19999 / 67411
7. Maximum data rate:22727 / 68417
8. Noise margin:7.1 / 6.8
9. Line attenuation:0.0 / 11.8
10. Signal attenuation:0.0 / 11.8
Downstream:65.83 Mbps
Upstream:19.53 Mbps
1 REPLY 1
Message 2 of 2
Re: Do my stats look ok for my speed?
As regards your estimated speed please use this checker. When you use the BT one it only seems to give the Range A estimate rather than both the Range A and B estimate. You could be on a Range B line.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Your line is in a training period and the speeds can fluctuate during that time.
Your stats look ok, your up noise margin might be slightly high but not drastically so. You are probably getting as good as you are going to get. The max data rate is what your line can support. This can vary from connection to connection due to variables such as quality of line and distance from cabinet.
