Message 1 of 26
Does BT have a DNS server?
If so, is it better to use their DNS server or...
25 REPLIES 25
Message 2 of 26
Re: Does BT have a DNS server?
your home hub automatically uses BT's DNS server
Message 3 of 26
My router?
Message 4 of 26
what router are you using and what DNS settings
Message 5 of 26
TP-Link
DNS : 4.2.2.3 & 4.2.2.5
Message 6 of 26
if those work ok for you then there is no reason to change the DNS settings
Message 7 of 26
I'm getting MAD AMOUNTS of DNS problems right now, more than ever.
Message 8 of 26
you could try google DNS and see if that helps
Guru
Guru
Message 9 of 26
4.2.2.3 & 4.2.2.5 seem to be Level3's free DNS service.
As john46 has said you could try Google's DNS service 8.8.8.8 & 8.8.4.4
BT's DNS servers are normally automatically assigned to the router unless the router is specifically told to use different DNS servers.
Also make sure the DNS settings on the device you are using is correct too.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 10 of 26
"Also make sure the DNS settings on the device you are using is correct too."
What do you mean?
I've also tried using all types of DNS errors but I'm still getting this "Windows cannot communicate with device or resource (Primary DNS)"
