Message 1 of 4
Does Halo 1 still allow you to use Parental Controls?
Can't find it now, but I saw a BT page somewhere, that listed what you got with all the Halo packages, and the Parental Controls line had dashes across all the Halo packages.
Thanks.
3 REPLIES 3
Message 2 of 4
Re: Does Halo 1 still allow you to use Parental Controls?
@juddster27
Yes, Parental Controls work on all BT Broadband services, as they work at network level and are not dependent on which home hub or other router you use, as long as you use BTs DNS servers.
Message 3 of 4
@juddster27  Don't take too much notice of the comparison charts the halo 1 with complete WiFi although it says it comes with a disc it has a dash against the necessary hub.
However yes parental control still works.
Message 4 of 4
Thank you, and to both of you for taking the time to reply.
