Message 1 of 4
Does it violate BT's T&Cs to allow my neighbour to use my broadband wifi?
I would like to let my pensioner neighbour use my wifi as they cannot afford their own. I do not require lectures about the wisdom of doing so. I only want to know if BT allows me to do so. I have spent some time in the T&Cs and can not find anything that prohibits it. Only a statement saying I am responsible for the activity of anyone I allow to use my network.
3 REPLIES 3
Message 2 of 4
Re: Does it violate BT's T&Cs to allow my neighbour to use my broadband wifi?
up to you who you allow to share your wifi
Message 3 of 4
That is the only proviso,  BT don't care or know who has your wifi password.
Message 4 of 4
If you mean you home wifi connection, then that is up to you. If you mean "BT-WiFi" then no, as that would mean given them your BT login details, which would allow them to access your account.
Bear in mind that BT do have a cheap broadband package for people on certain benefits, which may be an option for your neighbour.
https://www.bt.com/exp/broadband/home-essentials
