iradamson
Message 1 of 6
Does the BT Wireless Router Support VPN?
I am due to have a BT engineer install a BT Router for BT infinity, next week. I currently have a sky broadband subscription with a netGear router and I use this to connect to the network at work using VPN. I have colleagues who have had problems with their router unable to establish a remote VPN connection, does the Router provided by BT support VPN, because if not I cannot go ahead with the change from Sky as I work from home 3 days a week and I also need access to the network at work on evenings and week ends? Thanks if anyone can confirm this or not.
5 REPLIES 5
anthonyUK
Expert
Message 2 of 6
Re: Does the BT Wireless Router Support VPN?
I've tried VPN both in and out via the HH3 and it worked fine.
There is an option in the menu - VPN port clamping' which may be required if you experience problems.
Wicko9797
Message 3 of 6
i use VPN for work and for me it works fine
iradamson
Message 4 of 6
Thanks for the reply. That's what I wanted to hear!
iradamson
Message 5 of 6
davechapman
Message 6 of 6
Even if it doesn't work, you are not stuck with the HH3 - you can change it for another router if you wish. (perhaps your existing netgear will work).
