hoiyonkouma
Message 1 of 3
Does the SmartHub come with an ethernet cable?
Wondering if I need to go buy one otherwise
2 REPLIES 2
john46
Message 2 of 3
Re: Does the SmartHub come with an ethernet cable?
yes it does come with an ethernet cable or you can use one you already have
Dippu
Expert
Message 3 of 3
Not necessarily it depends whether you are upgrading your hub or whether you are having a new install / upgrade Broadband package. If up grading hub only then you will just get the hub and power supply.
