Message 1 of 15
Double NAT/port forwarding issues?
Having connection issues for a game, tried to port forward but my ports are still closed. They asked me to check for a double NAT by using tracert and I got 2 private IPs on my first 2 hops which I've read means that there is indeed a double NAT. I only have 1 device (the smart hub type a) and I've tried putting it into DMZ but to no avail, what can I do?
14 REPLIES 14
Message 2 of 15
Re: Double NAT/port forwarding issues?
No it doesn't. Is the second hop 172.16.12.xx, if so, that is the BT BRAS.
Post the tracert
Message 3 of 15
Message 4 of 15
No double NAT there.
Message 5 of 15
Alright, seems I was wrong then, but my ports still aren't open even after port forwarding so what could be the cause of that?
Message 6 of 15
Try turning off UPnP
Message 7 of 15
Still closed.
Message 8 of 15
The port will only be open when the application/game is running. How are you checking?
Message 9 of 15
I was using https://www.yougetsignal.com/tools/open-ports/ but I will try running the game and seeing if the issue is still there.
Message 10 of 15
Issue still present.
