treborf
Message 1 of 8
Down stream significantly reduced
Hello
Yesterday my line went completely dead - no tone or Infinity 1 connection for around 5 minutes. It came back up and all was well again.
This morning I noticed the HH6 rebooting itself and the downstream and subseqent download speed have been significantly reduced.
I ran a speed test through the router page and was told all was well! - even though I've lost some 9mb/s!!
I've checked for faults in the local area, but there are none to mention, but I see there's an open fault on my broadband. This coencided with the speedtest but I'd didn't report a fault - I simply performed a speed test. Would this mean that there is an issue with my line or is it simply the protocol of running a speed test?
Many thanks in advance,
Rob F.
Exchange Kingsmead / Cabinet 43
7 REPLIES 7
Webby
Message 2 of 8
Re: Down stream significantly reduced
Have you still got a dial tone? Have you done the quiet line test if you have a dial tone by calling 17070?
Can you post the connection stats from your router?
treborf
Message 3 of 8
Hi Webby
Many thanks for your reply!
I've still got a ring tone and the quiet test seems to be 'quiet' - no significant hum.
Webby
Message 4 of 8
Do you have the ability to see the maximum data rate and the noise margin?
treborf
Message 5 of 8
There's nothing on the router page to suggest these stats are available - can they be obtained elsewhere?
treborf
Message 6 of 8
Apologies, found them. I was typically getting 32mb/s but now it's around 24Screen Shot 2016-11-02 at 11.37.48.png
Webby
Message 7 of 8
Can you remove the faceplate from yur master socket and connect the router to the test socket using a filter and then repost the stats from the router when in the test socket?
I understand nothing in your house has changed but to rule out the chance of getting charged for an engineer visit you'll need to do it.
treborf
Message 8 of 8
Thanks again for the reply.
Via my account BT there's an acknowledgement that there's a broadband fault.
Thanks for your help
Rob.
