adrian109
Message 1 of 7
Downgrade from BT Infinity 2 to BT Infinity 1 - will DLM be reset?
Hi,
I have been on BT Infinity 2 for some time but the max download I can achieve is 25Mb so its not worth staying on the upto 80Mb version so have requested to be downgraded back to BT Infinity 1.
With the change in product will be line be subject to a DLM reset (as currently I think I'm on a banded profile) and another 10 day training period to determine a stable connection?
6 REPLIES 6
pippincp
Sage
Message 2 of 7
Re: Downgrade from BT Infinity 2 to BT Infinity 1 - will DLM be reset?
No.
adrian109
Message 3 of 7
Thats a shame I was quite hoping I would be! Am worried that I won't be getting the full speed if it stays banded.
Can you request a free of charge DLM reset or removal of banded profile?
pippincp
Sage
Message 4 of 7
WHich HH do you have? If a HH5 you can get the stats from the troubleshooting/helpdesk in the browser interface. Post lines 1-13.
If a separate medem and hub run as speedtest HERE and click on "Further Diagnostics" post back the full result.
Also post the result from HERE using the checker.
adrian109
Message 5 of 7
I was using a HH5 and it was constanly disconnecting. So have since swapped to my own Netgear router and an unlocked HG612 Openreach modem so I can monitor the stats.
Stats from HG612 modem:
=~=~=~=~=~=~=~=~=~=~=~= Plink log 2014.04.30 14:00:03 =~=~=~=~=~=~=~=~=~=~=~=
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 6919 Kbps, Downstream rate = 36772 Kbps
Path: 0, Upstream rate = 7026 Kbps, Downstream rate = 24999 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.3 6.0
Attn(dB): 0.0 0.0
Pwr(dBm): 11.9 4.8
VDSL2 framing
Path 0
B: 31 207
M: 1 1
T: 64 41
R: 10 0
S: 0.0407 0.9401
L: 8259 1770
😧 803 1
I: 42 104
N: 42 208
Counters
Path 0
OHF: 9564339 409494
OHFErr: 44 18
RS: 3672609121 607019
RSCorr: 162543 0
RSUnCorr: 2523 0
Path 0
HEC: 402 0
OCD: 30 0
LCD: 30 0
Total Cells: 1800493162 0
Data Cells: 2757887 0
Drop Cells: 0
Bit Errors: 0 0
ES: 360 246
SES: 17 0
UAS: 236 236
AS: 37501
Path 0
INP: 3.50 0.00
PER: 3.90 9.63
delay: 8.00 0.00
OR: 73.74 26.56
Bitswap: 2962 711
Total time = 1 days 4 hours 22 min 8 sec
FEC: 10492180 0
CRC: 6699 275
ES: 360 246
SES: 17 0
UAS: 236 236
LOS: 11 0
LOF: 10 0
Latest 15 minutes time = 7 min 8 sec
FEC: 736 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 2966 0
CRC: 1 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 4 hours 22 min 8 sec
FEC: 42512 0
CRC: 4 2
ES: 3 2
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 1433324 0
CRC: 2063 49
ES: 67 32
SES: 6 0
UAS: 19 19
LOS: 5 0
LOF: 5 0
Since Link time = 10 hours 24 min 59 sec
FEC: 162543 0
CRC: 44 18
ES: 15 18
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
xdslcmd info --pbParams
Status: Showtime
Retrain Reason: 2
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3971)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 6919 kbps 36772 kbps
Actual Aggregate Tx Power: 4.8 dBm 11.9 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 8.5 47.3 N/A N/A 20.1 57.8 87.3
Signal Attenuation(dB): 8.5 46.8 N/A N/A 20.1 57.8 N/A
SNR Margin(dB): 6.1 6.0 N/A N/A 9.1 9.5 N/A
TX Power(dBm): -6.1 4.3 N/A N/A 10.0 7.5 N/A
xdslcmd --version
xdslcmd version 1.0
DSL PHY: AnnexA version - A2pv6C035m.d22g
******* Pass *********
adrian109
Message 6 of 7
I was swapped over to BT Infinity 1 this morning and the downstream interleaving has been reduced from 800 to 19.  BT speedtest now looks like this:
Lets hope the line can stay like this 😉
legitimise_sailing
Distinguished Expert
Message 7 of 7
Looks like your DLM got reset 🙂
To say thanks for a helpful answer, please click the white star
