plus91uk
Message 1 of 6
Downgrade or not
I currently have unlimited Infinity2 but my contract is up next month will i notice a differnce if down grade to Infinty 1 i have attched a screen shot of hub stats
The reason i ask is that when i go to the adsl speed checker the speeds have dropped since i had it last Nov 15
and now
5 REPLIES 5
Webby
Message 2 of 6
Re: Downgrade or not
You're currently connected at 66meg. Infinity 1 has a max connection speed of 55meg. So you would see around a 10meg drop in speed.
However, you probably won't even notice it.
For perspective, 52meg (the max throughput you'll get on Infinity 1) is still enough to stream something like 10 HD streams simulatenously from the BBC Iplayer.
imjolly
Message 3 of 6
you would drop 11mb in connectuion speed and about same in download speed and if you don't download a lot of large file even though you and others in family stream a lot then moving  to infinity 1 is probably worth saving money  your up stream is only 12mb so dropping to 10mb on infinity 1 will not be noticable so again good reason to save money and move to infinity 1
if you decide to move to infinity 1 then phone options team who are uk based and they will help  0800800030
plus91uk
Message 4 of 6
Just called them very helpfull call centre and easy, managed to keep the same speed as on now but got a £7 mth discount new price starts from tomorrow even though my 18 months was not up till end May
Well happy Smiley Very Happy
Webby
Message 5 of 6
Perfect 😄
john46
Message 6 of 6
Great result 😞
