Message 1 of 10
Downgrade to BT broadband from Fibre?
I've been with BT for a year with BT Fibre Infinity and have had a whole host of issues.
Essentially, they cannot provide me with fibre worthy speed (am getting 5 - 14 mbps at best). So my question is... will my speed be slower than the speeds I am getting on fibre, if I change to standard broadband.
My theory is that it will essentially be the same. Just because I am on a fibre package does not mean my speed will be slower on standard broadband.... i.e. if my broadband package is 'up to 17mbps'
anyways, some help/advice would be great.
Many thanks.
9 REPLIES 9
Message 2 of 10
Re: Downgrade to BT broadband from Fibre?
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Message 3 of 10
FTTC broadband speed is dependant on your distance from the green cabinet and drops off very quickly, standard broadband speed is dependant on your distance from the exchange but the speed/distance graph is much shallower. If you are a long way from the exchange, FTTC may still be faster than ADSL.
Message 4 of 10
ADSL "Standard" broadband and VDSL "Fibre" broadband are two different products and there is no correlation between what you get speed on one to what you will get on the other.
VDSL Fibre broadband is delivered by fibre cables to a cabinet and thereafter along copper telephone cables to your property.
ADSL broadband is delivered along copper telephone cables from the telephone exchange to your house.
The main speed limiting factor on both systems is the length of the copper cables. In most, but not all, instances the Fibre Cabinet is nearer to the customer's property than the telephone exchange so the speed of fibre is generally faster than ADSL broadband.
Your previous posts about your poor speed has been fairly well covered in your previous thread.
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Switch-cabinet/td-p/1559354
Message 5 of 10
Message 6 of 10
According to the estimate check you can expect a maximum of 8Mbps for a "normal" broadband line. It could of course be slower.
EDIT: As per Webbys post. I did not give the "range" speeds. I was giving your Line rate which is the sync speed of your line and is probably more realistic of what you will get.
Message 7 of 10
ADSL2+ shows speeds of up to 14meg
Message 8 of 10
Thanks for your input guys. I really appreciate it. The conundrum is that I get standard broadband and it's a lot slower than fibre or I get fibre and pay the extra £120 and it's basically the same as Adsl.
Message 9 of 10
VDSL uses a 17.7mHz frequency as opposed to the 1.1 for ADSL and 2.2 for ADSL2+.
Higher frequency ranges don't work as well over longer distances like ADSL/ADSL2+.
I have on more than a few occasions recommended people swap from VDSL to ADSL because of the distances between their house and the cab/Exchange.
Message 10 of 10
Cheers John. Appreciate the answer. Best I can do is try it and upgrade if it doesn't work.
