bentech
Newbie
Message 1 of 8
Download Speed accurate. Upload slow.
I have a problem which is that i should be getting
Up to 76Mb Download
Up to 19Mb Upload speed
As you can see my download is accurate
The upload is way off.
Based on http://www.thinkbroadband.com/guide/fibre-broadband.html
and
http://recombu.com/digital/news/fibre-broadband-what-is-fttc-aka-fibre-to-the-cabinet_M10851.html
It shows how reduced the speed is based on distance to the cabinet
I have added the orange line which shows actual on left and what should be expect on right
I have drawn my distance and what speed i should be able to get up to
It shows that vdsl2 should be able to provide me with 40Mbps
Is there any reason my upload is so slow?
7 REPLIES 7
Message 2 of 8
Re: Download Speed accurate. Upload slow.
all speeds are up to speeds there is no guarantee of up load speed and certainly no one ever gets a 40mb upload with fibre to cabinet fibre to home more possible
will you please run  the BT speedtest  once the first test completes then run the further diagnostics test and  post back the results http://speedtest.btwholesale.com/
bentech
Newbie
Message 3 of 8
Hi
I don't expect to get 40Mbps i was just making the point that it doesnt seem to be a cabinet distance problem
The BT speed tester gave
Download Speed (Mbps): 67.80
Upload Speed (Mbps): 5.75
Ping Latency (ms): 25.63
Message 4 of 8
can you post the result asked for in the speedtest the further diagnostics one please
bentech
Newbie
Message 5 of 8
Sorry missed that part
1. Best Effort Test:  -provides background information.
 Download Speed
 70.74 Mbps
0 Mbps77.44 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 70.74 Mbps
 For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
 Additional Information:
 IP Profile for your line is - 77.44 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 8.9 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 8.9Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
Message 6 of 8
you could try a restart of the home hub only that has sometimes increased the speed but no guarantee
Distinguished Guru
Message 7 of 8
A better thing to try is to directly connect the PC to the modem and set up a broadband PPPOE connection. This will rule out the Homehub as it's not being used.
If not, I'll try again 🙂
bentech
Newbie
Message 8 of 8
Thanks for the suggestion.
It actually made lots of difference!
