Message 11 of 17
Re: Download Speeds Dropped Dramatically - Broadband Fault Not Fixed
Yes Java is enabled, and any extensions on each browser were disabled. At this point, browser and PC config issues can be ruled out entirely, and the problem lies somewhere between my router & the BT test site.
As I mentioned before, the second test was able to run once (out of over 30 attempts) leading me to the Tap3 test page which did not work as my router was unable to connect having changed the username. I've tried this several times as well (connecting with the speedtest username, as per the instructions).
Unfortunately, my free time is not unlimited and I am unable to spend hours trying to re-run tests & diagnostics that do not seem to work for me 99% of the time.
Is there any other way to proceed on my side (ie. another version of the diagnostic test)?
Or perhaps, is someone from BT able to conduct these tests remotely, if I provide my account details and phone number, to check for the cause of this issue? How do you deal with people who are unable to connect at all or have speeds too slow to run these tests?
Message 12 of 17
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Line noise will cause CRC errors which will affect your actual download speed.
Can you please provide BT Wholesale speed test results for different times of the day?
Use this link http://speedtest.btwholesale.com/
This may give some idea whether its a congestion issue.
Moderator
Moderator
Message 13 of 17
Hi @lenevaelena,
Thanks for posting. I'd like to take a closer look at this for yo so can you please drop me over an email with your details? You'll get the contact the moderators link in my profile.
@Keith_Beddoe I think part of this problem is the OP can't get the test to run correctly so we'll need to take a closer look at this.
Cheers
David
Message 14 of 17
Just sent you a message through the e-mail form in the link.
Thanks for the quick reply!
Moderator
Moderator
Message 15 of 17
Hi @lenevaelena,
Thanks for posting. I picked up your email today. I tried calling, sorry I missed you. I've tested your connection and there doesn't appear to be any faults. Can you try running the speed test again and post the results?
Cheers
David
Message 16 of 17
Hi David,
Apologies for not picking up, I was most likely at work during that time.
The speeds have improved significantly over the past three days, and I am now hitting my normal download speeds, which is strange as I have not changed anything in my config, as before.
I will consider the matter solved for now, and get back to the forum if the issue reappears.
Thank you for your help.
Cheers,
Moderator
Moderator
Message 17 of 17
Thanks for letting me know @lenevaelena, appreciate you taking time to do that. Please do post back if you have any other problems and we'll be happy to help.
Cheers
David
