Newbie
Message 1 of 2
Download/Upload Speeds dropped by over half
Got back from being away for 2 weeks on Monday and found out that my internet speed has dropped by quite a lot. I was achieving about 16/17Mbps download and 1.2Mbps upload. Now that download is around 5.5Mbps and the upload is 0.9Mbps.
Not sure what the cause of this is, any help is appreciated
1 REPLY 1
Message 2 of 2
Re: Download/Upload Speeds dropped by over half
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).  mst be done wired
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
