Message 1 of 18
Download speed deteriorating over a few days
Hopefully someone in the community can help me with this problem. Over a few days my broadband download speed will gradually deteriorate. If I go from a clean reboot of the hub I'm getting about 1.4 down (yes it's slow but that's normal for my location ). After a few days, less if I've done lots of downloading the speed goes down to a point my browsers says it's not connected. I use speedtest.net to check numbers and these match with BT line checker. Now a reboot of the hub will put me back up to normal speed. I had thought it was the hub but BT did send me a new one but it's not changed anything.
Any ideas, things I should check? Thanks in advance.
17 REPLIES 17
Message 2 of 18
Re: Download speed deteriorating over a few days
Should have added the stats report from the Hub . . . .
Message 3 of 18
Sorry, once again that resolution was awful
Message 4 of 18
the connection time is 1day+ was that a manual reset?
are you conencted to the test socket?  have you tried quiet line test  dial 17070 option 2  should be quiet and best with corded phone
your noise margin is low at 3.8db as normal is about 6db and this will probably drop further at night as more people use the lines resulting in more errors which in turn will slow down you browsing/downloading
can you run btspeedtester and when first test completes run diagnostic test and post results  should be done wired and don't reset before test
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Message 5 of 18
Thanks for the response imjolly.
Yes, this 1 day result was taken after a manual reset.
The quiet line test was fine, as much as i can tell, the line seemed quiet to me.  Not sure what you mean by test socket.  I'm plugging in directly to the hub (via ethernet) which in turn is going into the bt socket to the house (via the adsl filter) no extensions or anything.
The speedtester results are
Download speedachieved during the test was - 1.56 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :2.08 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 1.75 Mbps
The other test results are
Telephone Number xxxxxxxx on Exchange EAST KNOYLE is served by Cabinet 1
Featured Products
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Range(Mbps) | Availability Date
ADSL Max | Up to 1 | -- | 0.75 to 2.5 | Available
Fixed Rate | 1 | -- | -- | Available
Appreciate the help.
Message 6 of 18
that eliminates all your internal wiring from causing a problem
Message 7 of 18
OK, I've tried the Test Socket and no change, the numbers are comparable. I had to reboot the hub as it got unusably slow so they are different.
I may have misunderstood reading other posts on the forum but as i understand it the bt hubs will tailor themselves over time to an appropriate speed for the connection. Is it possible that if i have faults/errors on the line some how (FEC/Errors etc) that I'm seeing a slow down because of that?
Message 8 of 18
if you are still in the test socket with a new filter can you repost the new stats from your hub please
Message 9 of 18
These are the stats when plugged into the test port
Download speedachieved during the test was - 1.87 Mbps
Your DSL Connection Rate :2.11 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Message 10 of 18
sorry it's the stats from the hub like post 3
