Message 11 of 18
Re: Download speed deteriorating over a few days
Here are the new stats, while plugged into the test port.
Message 12 of 18
connection time only 5hrs was that due to changing to test socket or was it router dropping connection?
Message 13 of 18
That was from switching to the test socket
Message 14 of 18
your connection speed is lower than before but noise margin is up.  now see if that will hold connection with higher noise margin and repost stats tomorrow
Message 15 of 18
OK, so i grabbed screen shots over the last couple of days, this is all from the test socket and no restarts.  The core download speed has dropped to around 1.2mbps (via speedtest.net) but it is much moreconsistent, it does not appear to be dropping which is a result i think. The speed is a bit slower but acceptable and the consistency is more important.
Message 16 of 18
connection a lot more stable than before with 2+ days connection time
Message 17 of 18
Many thanks for the help imjolly.
Message 18 of 18
hopefully connection will be ok now
